FTP upoald issue
aubrey-ledbetter.epizy.com
when I upload my files to my website server using FTP, I receive the following message: 553 Can’t open that file: Permission denied. This event happens when I want to replace index2.html.
This does not allow my website to be updated with the files that I am uploading to the FTP, I have had this issue multiple times and have a feeling it has to do with a permissions block setting on my laptop.
Better check this one:
You should remove index2.html, you cannot edit it.
About uploading where are you trying to upload? Htdocs?
Are you using Monsta?
Try to access it using Control Panel.
