FTP connection
https://www.jubiladosinsurgentes.org
I’m still having problems connectig to FTP server. I’m using FileZilla, I dont’t have problems connecting to other servers.
I did all the suggested changes but still can´t connect. This is what I get:
Status: Resolving address of ftp.epizy.com
Status: Disconnected from server
Can you please help me?
Did you try the suggested fixes and workarounds from this article already?
did you read the article Meshin shared last time:
it has several possible ideas to help you.
Please let us know what you’ve already tried
I read the article, I changed password, used ftp.epizy.com, ftp.upload.net, 185.27.134.11, and checked my rooter configuration. I continue getting:
Could you also see if you can access the FTP server over a different network connection? Like when using a mobile hotspot or a VPN? That should rule out a lot of ISP level blocking.
I tried with the movile hotspot and got the same answer. I have another site in IONOS and I have no problem connecting with their FTP server.
I checked it for another topic, and we confirmed there that multiple ISPs in Argentina appear to be blocking access to our FTP server. Since you seem to be connecting from there too, you’re probably affected by the same issue.
So the answer is the same too: we cannot fix this from our side, you’ll need to check this with your ISP to try and get the block lifted.
Yes, that must be the issue, I connected through Proton VPN and had no problem. Thanks
