Fix for stubborn browsers cache and css files
Hi, sorry but I didn’t know how to use this code. My code looks like this:
<link rel=“stylesheet” href=‘styles/header.css?<?php echo filemtime($_SERVER["DOCUMENT_ROOT"] . "styles/header.css"); ?>’ / and > at the end
My file is php and there are no problems in the console, can you help me?
try this
<link rel='stylesheet' href='/styles/header.css?<?php echo filemtime($_SERVER["DOCUMENT_ROOT"] . "/styles/header.css"); ?>' />
im assuming that your styles directory is in the htdocs root directory
basically the full directory path is required
I have found a solution, you don’t have to change extension of index.html to .php
Solution -
Add version number and increment it every time you make changes to css. Sample code is right below. Check it. Worked for me anyway!
Sure, that is a good idea if your website is static. But if your website is dynamic and uses PHP a lot, then why not?
You could also do what Oxy suggested:
To clarify, you mean the file inside the /htdocs folder, yeah? And would it be okay if I only have these lines, and nothing else? (:
I am having a “stubborn cache” issue, and would rather not change my actual files. It seems I need to always use hard-refresh (Ctrl+Shift+R) to see the actual, updated index.html of my website…
I found that even after ctrl-shift-r that my firefox browser would still display the cached .css file instead of my recent changes which forced me to think of this filetime solution :frowning:
firefox can be annoying sometimes
Thank you so much, you’ve really saved my life. Until now, all I’ve been able to do is add a version of myself (?v=2) every time I make a style change. :slight_smile:
Another sanity saved :+1:
:rofl:
