Files inside subfolders return a 404 Not Found error.
/testfolder/test.html — 404 Not Found
/BankAccountManagementSystem/index.php — 404 Not Found
Accessing /testfolder/test.html over HTTP returns a 502 Bad Gateway error from OpenResty.
Files directly inside htdocs work correctly.
Hello!
I’m hosting a PHP project on InfinityFree, and I’m having trouble accessing files inside subfolders.
My domain is php-projects.rf.gd, and its configured directory is htdocs.
Here are my test results:
The file /test.html works correctly and displays my test message.
The file /testfolder/test.html returns a 404 Not Found error.
The file /BankAccountManagementSystem/index.php also returns a 404 Not Found error.
The files are visible in File Manager and are located inside the expected folders.
I checked the htdocs directory and confirmed that no .htaccess file is present.
Since files directly inside htdocs work but files inside subfolders do not, could this be related to subdirectory routing, document root configuration, or server-side handling?
Could you please help me identify the cause and suggest a solution?
Can you tell me exactly what you see for https://php-projects.rf.gd/testfolder/test.html, and whether it’s the same every time you load it? Your post mentions both a 404 and a 502 for that same file. Those are different problems, so I need to know which one is happening now. A screenshot or the exact text on the error page would help.
Also, can you tell me the exact path of the file in File Manager, such as htdocs/testfolder/test.html, including upper and lower case? Server paths are case-sensitive, so TestFolder and testfolder are different folders. I also need to know the file is inside htdocs itself and not in a folder next to it.
The 502 may be a separate, temporary issue. Someone else reported a short-lived 502 from OpenResty on the same day, and their site recovered by itself after a few minutes:
That’s only a possible match. I found nothing on the forum that explains subfolders returning 404 while root files work, so the answers to the questions above should show where to look next.
File Manager issue:
When I open htdocs and click the testfolder directory, File Manager displays “Failed to load folder contents”. Therefore, I cannot currently verify the contents of testfolder through File Manager.
The solution button means that you have your issue sorted out, not that you are asking for solutions. I have removed the status from your post as it seems that you are still seeking help.
Seeing how your folder names contains random uppercase letters makes me worried, as our servers are case sensitive (as with most hosting services), so test and Test are two different files.
Normally we ask people to always use lowercase letters to avoid the confusion, but if you insist on using different cases make sure that it actually matches the file name you have uploaded to your account.
I checked it and I see the issue. The file manager shows this incorrectly, but FileZilla does show it: the actual folder name is not testfolder, it’s testfolder, with four preceding spaces.
