FileRun Problem
My website URL is:
http://drive.omroepcomeback.ga/
The problem is:
When i’m trying to set up home folder for a user, it says that the folder doesn’t exists, but I have created the folder
I’m using this software:
Filerun (filerun.com)
Additional information:
Self installed using PHP Script
Under the InfinityFree terms and conditions, you aren’t allowed to create any file sharing/storage scripts on your account, as stated under the script usage terms (point 10) The Terms Of Service can be found at Terms of Service - InfinityFree . It might be worth trying to contact the admin about this to see if you can get permission, but I can already see that everything other than unzip.php (which is broken) has been removed.
