https://errors.infinityfree.net/errors/403/
403 Forbidden
Server or website configuration is blocking you from viewing this page
please solve this problem asap
403 Forbidden
Which address are you seeing the 403 on? The link you gave is our error explanation page, not your site. Also, have you uploaded any files to your site’s folder yet?
Your hosting account was only created a few minutes before you posted, so my guess is the folder is empty or has no index file. I can’t confirm that from here. This article covers the common causes of a 403 on InfinityFree:
The two most likely causes for a new account are:
htdocs folder. The Directory Status card on the domain’s Manage page in the client area shows the exact folder your files need to be in.index.php, index.html, index.htm or index2.html, in that order. File names are case-sensitive. If none of them is in the folder, you get a 403.If your files are in the right folder and there’s an index file, tell me the exact page address that fails. Also tell me whether your .htaccess has any deny from lines, or whether the URL contains “chat” or “includes”. The article says those keywords are blocked.
Can you share a link to your actual site for us to help?
As the bot said:
But also if you’re using a custom domain (rather than a free subdomain) and it’s not been properly added to your account that can cause the same error
