Facing critical issue
apnamall.ml is my website name,
I am facing critical issue in my website earlier I followed the instruction through email as they told me to change WP_DEBUG to true. but still, I am facing the issue,
My website is not opening since I started back up of it, I don’t know what kind of issue is this but please check it out I delete recently the “All in One WP Migration” plugin files from the file manager in hosting, but there isn’t anything positive response
Welcome!
Please read this article before creating a topic.
i deactivated the broken plugins but still facing that issue
if you check so i mentioned that after doing the wp_debug true still there isnt showing issue , main problem is this
Maybe this will help?
Hi there, I had a simulated issue, then tried to manual update WP, but… made it worst…
So this is how i fix it
, i log in to infinityFree , control panel and then went to softaculous apps installer
I ether did a reinstall the WP app or updated WP from here.(sorry i cant remember)
works fine now and im on the lastest version :slight_smile:
oh once you have fix it make sure you click that backup button
