I understand that InfinityFree provides automatic system-wide SSL certificates for free subdomains and that manual certificate installation is no longer supported.
Could you please investigate why my website is still serving this expired wildcard certificate and renew or replace it with a valid system-wide SSL certificate?
This website is part of my academic thesis project, and I need HTTPS working properly for testing and presentation.
Your hosting account has a free subdomain called communitylink, but it’s under a different domain ending than the infinityfreeapp.com address in your post. The IP in your SSL Labs report (185.27.134.24) also isn’t the website IP of your account. Could you check the subdomain in your members area and tell me which domain it actually shows? I’d like to know whether communitylink.infinityfreeapp.com is really the address you were given for this site.
Then try opening the same name under the domain your account actually lists, using https://, and tell me whether Edge still shows NET::ERR_CERT_DATE_INVALID. If it loads fine, the expired certificate belongs to the other domain and not to your site. If it shows the same error, that tells us the problem is wider than that one domain.
The domain communitylink.infinityfreeapp.com is not on your account, and the IP address 185.27.134.24 is not the IP address of your hosting account.
That IP address is the IP where we point non-existent domains to, which shows an information page. It’s a known issue that that IP address uses outdated certificates. While that’s not ideal, it has no impact on your actual websites.
I checked the actual domain name assigned to your account, and that seems to be working perfectly, the website works including the correct, system wide SSL certificate.
