Nothing on your side can fix this. The certificate sits on the FTP server, so only whoever runs that server can renew it. I couldn’t find a current announcement or a renewal date for it.
The same thing happened in 2023, when the certificate for ftpupload.net expired and no new one had been installed. The reply on that topic said iFastNet had been asked to renew and install it, and that the existing certificate was “safe enough” in the meantime.
That reply was about the 2023 expiry, so I can’t say the same applies today. To compare, does the certificate FileZilla shows have the same details as in your post, including the Sectigo issuer and the 28 October 2026 expiry? Please also say whether the warning comes up for every connection or only the first one.
The SSL certificate was just renewed, and the new certificate is now being used by the FTP server.
Note that FileZilla will still warn you about this. FileZilla always warns you when there is an unknown certificate (not necessarily an untrusted certificate). But unless FileZilla says that something is wrong with the certificate, you can safely accept it.
