I have modified it to true and now my site is not loading. Just look what he shows
https://socialtemplates.store/
I have deactivated all the plugins and my website was doing normally, after activating Woocommerce, I received the database error message. What should I do? Uninstall woocommerce?
Well, I think the first step is to figure out what the actual database issue actually is.
To do so, you can enable WP_DEBUG mode in WordPress: Debugging in WordPress – Advanced Administration Handbook | Developer.WordPress.org
Then, when you see the error, you should get a more detailed error message.
If you get the error intermittently, it’s likely that the error you will see is the one covered by this article:
But again: please make sure to check the error message first before taking actions that may not be helpful.
I have enabled the Wp_debug but most of my plugins are deactivated right now, I’m only using elemntor. This is the message I received:
content/plugins/elementor/includes/elements/container.php on line 42
Deprecated : Creation of dynamic property Elementor\Includes\Elements\Container::$logical_dimensions_inline_end is deprecated in /home/vol1000_8/infinityfree.com/if0_35179772/htdocs/wp-content/plugins/elementor/includes/elements/container.php on line 43
Deprecated : Creation of dynamic property Elementor\Includes\Elements\Container::$logical_dimensions_inline_start is deprecated in /home/vol1000_8/infinityfree.com/if0_35179772/htdocs/wp-content/plugins/elementor/includes/elements/container.php on line 42
What should I do?
This is not an error, you may upgrade elementor manually when possible though.
The side effect of WP_DEBUG is that it will show ANY message, not just error message. It will also show non-breaking recommendations from PHP.
These messages do not indicate any issue you’ll need to fix. You can (and should) simply disable WP_DEBUG when you have the database error message to remove these messages.
