"Error establishing a database connection" (NOTHING HELPS)
Its a pretty simple process.
@anon5274116 you must have an idea of what you used as your db login information when signing up and if not then just create another one while making note of the details carefully.
Once you confirm on your email with the link use phpMyAdmin to access your db.
working on it now, thanks.
I get this error:
#1046 - No database selected
To be clear, I opened the sql file, and copied/pasted the contents in the sql area of phpmyadmin.
I have put the name of the new database into the very top part
– Database: mydatabasename
send your sql to me on [email protected] and I’ll get back to you over email.
