Error 2002 SQL
https://ggram.golden-devs.rf.gd/testbd.php
Hosting account: if0_38891559
MySQL host: sql203.infinityfree.com
Database: if0_38891559_ggram
PHP 8.4.25 with PDO MySQL is running inside the same InfinityFree
hosting account, but the connection returns:
SQLSTATE[HY000] [2002] Connection refused
The hostname and database credentials were copied directly from
the MySQL Databases page. Please check internal connectivity,
firewall rules and account mapping between my hosting account
and the sql203 MySQL server.
none
Could you post the part of testbd.php that builds the connection (the DSN, host, port and username, with the password removed)? Could you also say whether you can open the database in phpMyAdmin from the control panel? If phpMyAdmin works, the database server is up and the problem is in the connection details your script uses. If it fails too, that points at the server side, and a person would need to look at it.
I couldn’t find an answer for [2002] Connection refused from a script inside a hosting account. The only topics I found were about external databases or other setups, so they may not be the same problem. The nearest source is the article on common connection errors. It says the hostname must be the one shown under MySQL Databases, not localhost, and that the password is the hosting account password, not the members area one:
Your account’s database server does match sql203. So the next thing to check is whether the script sends exactly what the control panel shows, for example a custom port or a different host string in the DSN.
<?php
declare(strict_types=1);
header('Content-Type: text/plain; charset=utf-8');
try {
    $config = require \__DIR_\_ . '/config/app.php';
    echo 'PHP: ' . PHP_VERSION . PHP_EOL;
    echo 'pdo_mysql: ' . (extension_loaded('pdo_mysql') ? 'OK' : 'MISSING') . PHP_EOL;
    echo 'sessions writable: ' .
        (is_writable(\__DIR_\_ . '/storage/sessions') ? 'OK' : 'NO') .
        PHP_EOL;
    $pdo = new PDO(
        'mysql:host=' . $config\['db_host'\] .
        ';port=' . $config\['db_port'\] .
        ';dbname=' . $config\['db_name'\] .
        ';charset=utf8mb4',
        $config\['db_user'\],
        $config\['db_pass'\],
            PDO::ATTR_ERRMODE => PDO::ERRMODE_EXCEPTION,
            PDO::ATTR_DEFAULT_FETCH_MODE => PDO::FETCH_ASSOC,
    echo 'DATABASE CONNECTION: OK' . PHP_EOL;
    $tables = $pdo->query('SHOW TABLES')->fetchAll(PDO::FETCH_COLUMN);
    $required = \[
        'users',
        'messages',
        'user_blocks',
        'user_favorites',
        'message_reactions',
        'message_hides',
        'conversation_clears',
        'conversation_pins',
        'auth_limits',
    foreach ($required as $table) {
        echo $table . ': ' .
            (in_array($table, $tables, true) ? 'OK' : 'MISSING') .
            PHP_EOL;
} catch (Throwable $error) {
    http_response_code(500);
    echo 'ERROR TYPE: ' . get_class($error) . PHP_EOL;
    echo 'ERROR CODE: ' . $error->getCode() . PHP_EOL;
    echo 'ERROR: ' . $error->getMessage() . PHP_EOL;
here code to test connection, and his give me 2002 error
I had a hunch, so I hope you don’t mind that I added an extra line to the testdb.php script, which shows the contents of the $config['db_host'] parameter.
When you run the page now, you’ll see that the actual host used is 127.0.0.1, not sql203.infinityfree.com.
So that’s why the database connection fails: you’re connecting to the wrong host. So you’ll need to fix that to be able to connect to your database from your website.
https://ggram.golden-devs.rf.gd/testdb.php
