Err_ssl_protocol_error
[epiz_26632036]
www.smartdevicez.com sent an invalid response.
ERR_SSL_PROTOCOL_ERROR
Not sure what the issue is. I’ve tried using several different landing pages with the same outcome. Any ideas?
Many thanks!
You will need to install a SSL certificate on your hosting account, but first you will need to generate it from the “SSL Certificates” section of the Client Area. After generating the SSL certificate from that section follow this article to install it on your hosting account.
Thanks, that helped!
