Err_ssl_protocol_error
Hi guys, my website quinem(dot)com not working, pls help me.
The ERR_SSL_PROTOCOL_ERROR means you are trying to trying to access the website over HTTPS, but your website doesn’t have an SSL certificate yet.
You basically have two options to fix this:
  • You can install an SSL certificate on your domain name. You can use our SSL Certificates tool in the client area to get a certificate for free.
  • You can update your website configuration to not redirect people to HTTPS anymore.
Hi, I had installed a free SSL (plugin) in my wp-admin.
I use Really Simple SSL.
As far as what I understand correctly you do not even have an SSL certificate on your site, I’m not sure but even that plugin said “Order an SSL certificate”?
Just because you install a WordPress plugin doesn’t mean you will already have an SSL certificate installed on your site. I also checked your site using an SSL checker and you don’t actually have an SSL certificate installed.
If you want to get a free one, you can go to the client are and on the menu you can see an “SSL Certificates” tab and just follow the instructions already provided there.
