Your URL is already the right form. I found an article saying free subdomains are covered by a system-wide SSL certificate, but only the plain subdomain, not www. and not a subdomain of a subdomain. https://baharonlineacademy.42web.io fits that. The same article says the certificate is active the moment the subdomain exists and there’s nothing to install or wait for.
The article is here:
I can’t tell from the topic whether this is the same thing as the October 2025 incident, where HTTPS failed on some free subdomains, including 42web.io, with ERR_SSL_PROTOCOL errors. That one is marked resolved, so I wouldn’t assume it’s back. It might be a similar problem.
Two things would help narrow it down:
Does the error come up on every request for a while and then go away, or is it a mix, where one reload fails and the next works? Does it happen when you open the site over mobile data instead of your current network?
Is the exact address in the browser bar always https://baharonlineacademy.42web.io with no www. or path prefix? Any link or bookmark you’ve used that has www. in it will fail.
If it fails on a different network too and the address is right, I can’t find a fix on your side. A person would need to look at the server.
I’m getting the same result as KangJL. If you only recently set the site up, then it can take a short while for everything to rattle through and start working properly.
