Err_connection_timed_out
sofiafm.ga
ERR_CONNECTION_TIMED_OUT
Yesterday it worked fine, today the page takes a long time to load and shows the mentioned error message.
Is it a general problem with the InfinityFree or just with my IP?
How can I fix it?
I have simmilar problem here.
The traffic is through cloudflare and custom domain, got error 522 Connection timed out between cloudflare and host.
Is there any webiste that shows status of InfinityFree servers?
Your website is working fine.
But it sucks 8.5GB of RAM all by itself!
2021.04.25_21h30m47s
Can you enter mine?
ryder.cf
I just saw it started working.
Thanks :slight_smile:
No. Yours is throwing timeouts. 522 Error.
Did you use the Cloudflare integration from the Vpanel?
Aight, I guess I need to wait
Thanks
Now It works!!!
