Err_connection_timed_out
https://capacitacioneslitoral.site.je
ERR_CONNECTION_TIMED_OUT
hola, quiero entrar a WordPress para seguir con la pagina y me da ese error, ayer no pasaba me desperté hoy con esto
Your site is on an active account, so this looks like a connection problem rather than an account one. The first thing to find out is whether the site is down for everyone or only for you.
I found an article that covers exactly this error. Put your address into check-host.net and click HTTP, as the article describes. Then open the site on your phone with Wi-Fi off, so it uses mobile data, or through a VPN.
Do most locations on check-host.net show OK? Does the site open on mobile data or a VPN?
The article explains that these errors mean your browser couldn’t set up a connection to the server. It lists three possible places for the block: your device, your network or provider, or the server blocking your IP address. Those two results tell you which one it is.
Here is the article:
Hello, I need help with my website.
Website: https://capacitacioneslitoral.site.je
The website works correctly on my PC, but it cannot be accessed from some other networks.
For example:
  • On my mobile phone using mobile data without a VPN, I get: DNS_PROBE_FINISHED_NXDOMAIN.
  • When I use a VPN on the same phone, the website works.
  • The website also works from my PC.
  • Other people in different locations have also tried to access the website and have been unable to do so.
I checked the DNS and the A record for the domain points to:
185.27.134.142
The domain is also shown as Active in my InfinityFree account.
Could you please check if there is any DNS, nameserver, server, IP blocking, or network access problem affecting this domain?
I want to make sure the website can be accessed normally from different networks and countries.
Thank you.
What you’re described so far matches an ISP level block by your mobile carrier. That would explain why it doesn’t work on your phone and for other people, but it works on your PC and through a VPN.
I very recently published an article in our knowledge base about this specific error message.
It contains a few additional investigation steps you could try. Some of the steps might be hard to do from a phone, but you could for example use your phone as a mobile hotspot from your PC to do troubleshooting on the connection.
