The script installer continues to give me the error ERR_CONNECTION_TIMED_OUT
This is generally caused by the port of Softaculous being blocked on your network. Softaculous is accessed on port 2082, the same port as cPanel uses, and some network administrators choose to block all unknown ports on their network.
You can work around this by using a VPN, or just using a different network. Or you can contact your network administrator and ask them to unblock this port.
Okay
