ERR_CONNECTION_RESET on kooora.kesug.com - even static HTML fails
http://kooora.kesug.com/
Hello,
My website is kooora.kesug.com
Hosting account:
if0_43093006
Server IP:
185.27.134.154
The website suddenly became inaccessible and returns ERR_CONNECTION_RESET.
I tested:
  1. Homepage /index.php - ERR_CONNECTION_RESET
  2. /news-test.php - ERR_CONNECTION_RESET
  3. /test.html - ERR_CONNECTION_RESET
The important point is that even the static HTML file test.html cannot be accessed.
DNS resolves correctly:
kooora.kesug.com → 185.27.134.154
The hosting account is Active.
phpMyAdmin is accessible and the database exists.
The static HTML file also fails, so this does not appear to be only a PHP or database problem.
Could you please check whether there is a problem with my hosting account, website configuration, or server/IP 185.27.134.154?
Thank you.
Additional information:
The problem affects both PHP and static files.
Test results:
  • /index.php → ERR_CONNECTION_RESET
  • /news-test.php → ERR_CONNECTION_RESET
  • /test.html → ERR_CONNECTION_RESET
DNS:
Hosting account status: Active
Database/phpMyAdmin: Accessible
The static test.html also fails, so this does not appear to be only a PHP or database problem.
Please check the web server, hosting account, domain configuration, and server/IP 185.27.134.154.
Does the site load from a different network, like mobile data, or through a VPN? That would show whether the problem is on your side of the connection or on the server’s.
I found a topic that might be the same thing. Someone got ERR_CONNECTION_RESET on their rf.gd site, even though the account looked fine. Their fix was to open the site through a VPN, which worked for them. They concluded that their connection to the server was being blocked on the way, not that the account was broken.
Here is that topic:
I can’t tell yet if yours is the same. Your test with test.html does fit it, because a static file failing suggests the request is dropped before it reaches your files.
Your hosting account was created yesterday, so I’d also like to know whether the site ever loaded for you, or whether it has failed since you first opened it.
If it fails on every network and VPN you try, a person needs to look at the server side, because I can’t check that from here.
Update:
I tested the website using a VPN with a US server.
The website works perfectly through the US VPN.
Without the VPN, from my normal internet connection, I get ERR_CONNECTION_RESET.
This happens even with the static test.html file.
So the issue appears to be related to the network route or connection between my ISP/network and the server IP 185.27.134.154.
Sorry for the delay. I wrote a draft but forgot to send it before closing the tab.
Yes, a Connection Reset error usually means a connection issue between your browser and our server. It doesn’t really matter which file you’re requesting, because typically the connection doesn’t get to a point where the browser even gets the chance to ask.
So what you’re seeing that pretty much confirms a network block between you and the server. What it doesn’t tell is who is doing the blocking.
It could be a block on our end. We temporarily block IP addresses that show abnormal traffic for 24 hours to protect our servers against attacks. If so, that block should be lifted automatically.
However, it might also be your ISP or network administrator that’s doing the blocking. Free hosting unfortunately has a bad reputation and some network administrators choose to block access to some of our IP addresses as a security precaution.
Since you asked your question, I created a new KB article that goes into connection issues, and has some additional troubleshooting steps. Maybe you could check it?
