Entry process
In my mcsellers.com account i am using a single php script it is a type of smm panel but in few visits its showing suspended on opening my account it is showing entry process limit i donot know why still i am using single php script.
Welcome!
Your website is working just fine for me. Can you try clearing your cache?
Thanks!
The number of scripts is irrelevant for most metrics, it’s what those scripts do and how they are used that makes all the difference.
I don’t know what “SMM” means, or how that would affect the usage of your site. But if you’re consistently hitting the limits, you either need to fix that or upgrade to premium hosting.
