Entry Process Failures Reached Very Easily on Idle
@Admin Okay So the problem did not actually solve on the account epiz_27588241 with domain Artsinator.ml . I made a fresh install of Wordpress using Softaculous and checked out console when I visited it first time and there are many 508 Errors. Did some optimization to call less request using WP Fastest Cache and few 508 errors still pop up. I don’t know why is it happening.(thought it was SQL but no making php stuck but now again after fresh install??) So to compare I have created a Similar website with different domain (fishmarketer.ml) on an alternate Infinity Account epiz_26681576 with Same plugins plus some extra plugins (why not?) to test and here is a surprising result.
(Gets 508 Error) [The Account in Question for this topic is this]
Account with problem has domain https://Artsinator.ml ones ( epiz_27588241)
WP Admin section also created more 508 Errors.
(Gets No 508 Error even with extra plugins) (epiz_26681576) [Test Account for comparision]
A Duplicate Test Website has none similar plugins and about 5 more extra : https://fishmarketer.ml
WP Admin section also created No Errors even with many plugins… like 25 plugins :upside_down_face:
Note: Both uses different Accounts.
And I did some testing on both sites before I posted this reply.
Remember, I reinstalled Artisinator’s Wordpress and the 508 error still persisted.
In Short, epiz_27588241 Creates lots of 508 errors. A Duplicate Account is created with similar Settings and Plugins with little bit more plugins added and it does not create any errors at all. The Reason to Create this Topic is that it is creating lots of Entry Process Limits to conclude into Account Suspension due to this bug.
Can you please check?
On yeah I got the same error as well.
And yeah 20-25 plugins is actually a modest number of plugins
Admin have you checked?
Guess I will delete that Account and Use Another One as that would be the only good solution now.
