Emails not arriving
I have this problem from 3 days ago, I cant receive emails. Yes, I have all the configurations set as I could receive emails some days ago and now they dont arrive.
Hi,
Did you enable Cloudflare on vPanel?
If so, then that’s the problem, Cloudflare breaks incoming emails.
@UnknownLolz said:
Hi,
No I didnt. I could perfectly receive mails some days ago. I didnt change anything.
Hi been having problems of i can recieve email pls how can i fix it
Hi been having problems of i cant recieve email pls how can i fix it
Simple: create a forum discussion (don’t hijack someone else’s topic) where you describe which accounts are affected and what symptoms you see.
What’s the email address? Or at least the domain and whether it’s an email account or a forwarder.
It is a forwarder. Domain: ingenierous.ml
Did you check this article? https://infinityfree.net/support/email-forwarders-and-gmail/
Ok but is this article new? Because 2 or 3 days ago I could receive forwarders on my gmail
I have the same problem when using normal email accounts with roundcube, emails arent arriving.
No, this article was written a long time ago.
If you read the article, you understand know that Gmail is blocking the forwarded messages. If something changed on Gmail’s end, that could result in the forwarders working or not working anymore.
That said, I think the issue may have been caused by the greater issue on the mail servers right now: https://forum.infinityfree.com/discussion/comment/18713/#Comment_18713
