Domain publish issue
I’ve created an account on infinityfree.net.
I am new to this hosting server, so I don’t know how to solve some issues.
I’ve searched the related topic in this forum, but no topics suitable for my issue.
I purchased my domain through namesilo website, and I added the domain to my infinityfree account.
So I can access to control panel and browse the file manager and PHPMyAdmin.
Also, I’ve created the index.php file with some code in htdocs folder.
Then I browsed my domain in chrome, but it only displays some ads page with search links.
How can I solve this issue?
I would appreciate that somebody let me know.
Thanks.
What is your website URL, so that I can help you?
Thanks for your reply.
URL is http://saturn525.com
Your domain is pointing to the right nameservers, but it seems like the DNS records have been corrupted. Can you please change the nameservers to ns1.byet.org, ns2.byet.org, ns3.byet.org, ns4.byet.org and ns5.byet.org from your NameSilo’s Nameservers Management Panel for your domain, then remove and add the domain again from the “Addon Domains” section of the Control Panel and wait within 72 hours for the changes to be applied?
I have added the nameservers to ns1.epizy.com.
When I added the domain to my infinityfree account, it required to set the nameservers as ns1epizycom.
So should I change the nameservers to ns1.byet.org, etc?
Epizy and Byet nameservers are the same (they point to our hosting the same), but Byet nameservers are 5, so they are more reliable than Epizy ones.
Thanks for your answering.
I will try to add the nameserver to Byet again.
Ah, and also:
After that and after some hours, your website will be working fine.
Ok, sure
Thank you very much.
Hello Ergastolator1,
I have one question.
I’ve tested to remove and add the domain again.
After I changed, I browsed the file manager.
Then it has created “saturn525.com” folder.
Do I have to work in this directory?
Yes, you have.
Thanks
Hi, Ergastolator
I’ve solved my issue, it works well now.
