Hi I am wondering to see if Fossbilling works on InfinityFree or is that premium?
Instead of asking for “whether it works”, please just test it out so that you’ll know if it works or not.
You tell us. Just try it!
If it works, you know it works. If it doesn’t work for some reason, we can discuss the issues you’re having here.
A quick look at the system requirements doesn’t show any obvious blockers, but that’s not a guarantee it will work of course.
Please understand that while we know our hosting, we don’t know every bit of software ever created. So unless we know of a website that is using that particular software successfully or unsuccessfully, we generally cannot really predict whether software will work or not.
I tried it and it will setup and install, but when you try to login you get An exception has been thrown during the rendering of a template (“Call to undefined function Symfony\Component\HttpClient\Response\curl_multi_exec()”) in “mod_index_dashboard.html.twig” at line 8. Because curl_multi_exec() is disabled on free hosting
well I guess that answers your question. No FossBilling doens’t work on InfinityFree…
I’m like 90% certain curl_multi_exec() isn’t enabled here ![]()
Unless someone modifies the code for workarounds ![]()
Ask the developers, or maybe work with the code yourself (if licenses permit.) Sorry to hear that Fossbilling does not work, but we’re glad you gave it a try, in case anyone in the future ever tries it themselves!
