Dns_probe_finished_nxdomain
https://reservasimypetmartsby.rf.gd/
Hello InfinityFree Support,
I am experiencing a DNS resolution issue with my domain:
The domain is listed as active in my InfinityFree control panel, and the website is still accessible from a computer that previously opened it. However, mobile devices cannot resolve the domain and display DNS_PROBE_FINISHED_NXDOMAIN.
I checked the domain using Google Public DNS and received:
  • Status: SERVFAIL (2)
  • Error: Name servers did not respond
  • Nameserver IPs: 198.251.90.216 and 198.251.86.153
  • Extended DNS error: 22
  • Delegation: rf.gd
Could you please check whether the authoritative nameservers or DNS delegation for rf.gd are experiencing an issue?
I have not changed any website files or DNS settings.
Thank you.
i have problem with my project here
I think this matches an open incident on our status page. It’s about DNS resolution failing because our nameservers aren’t responding from a us-west monitoring location.
That fits what you saw. Google Public DNS reported “Name servers did not respond” for rf.gd. It would also explain why the computer that opened the site before still works while your phones don’t. A device that has the answer stored can keep loading the site, and one that has to look it up fresh gets the failure. The incident says websites may be unreachable for visitors in the affected region.
To tell whether you’re in that region, which country and area are your phones connecting from, and which internet provider do they use? You can also run your domain through dnschecker.org with record type A. If the failures are mostly in the western US, it’s the incident.
Our article on this error covers the dnschecker steps and what each result means:
