Dns_probe_finished_nxdomain
facilitamais.freesite.online
Error Message : DNS_PROBE_FINISHED_NXDOMAIN
Website suddenly stopped working, i don’t know what happened. Is this domain (freesite.online) suspended again?
Hi and welcome to the forum!
I think so; this time, though, when I did a WHOIS lookup, it reports a clientHold status code instead of the serverHold I used to see in the past for the first suspension. The outcome is still the same, so the domain is still not enabled on the DNS and we have to wait until it gets finally fixed.
Thank you for replying.
Do you think it will take a long time to be fixed? I have a presentation tomorrow where I must show the website
The domain (freesite.online) is probably suspended for now. So you can’t see your certificate as found even if it is installed.
I can’t say because it is a suspension. There is no specific time, but nothing should prevent you from moving your files to another InfinityFree subdomain.
