DNS / Nameserver Configuration Issue – zarchy.co.zw
zarchy.co.zw
I need assistance configuring my domain zarchy.co.zw.
ZISPA has sent repeated warnings that the domain has nameserver/DNS errors. The domain is registered through Webzim, while the website is hosted on InfinityFree.
I am currently unable to properly configure the nameservers/DNS records required to connect the domain to InfinityFree.
Please assist me with the correct nameserver configuration for zarchy.co.zw and confirm what DNS records I need to add or change on the Webzim side.
Thank you.
have ZISPA told you exactly what is incorrect about the settings? Unfortunately, thats not something we can find out for you.
When going to add a custom domain to your account, it’ll tell you what the name server settings. But in short:
ns1.infinityfree.com
ns2.infinityfree.com
If thats set up and there are no errors on your infinityfree account, you’ll need to work with ZISPA to find and fix the problem
they give me this ZISPA automated warning: Continuing nameserver errors for domain zarchy.co.zw
Inbox
Summarise this email
ZISPA Registration Warning
02:46 (8 hours ago)
to dns, tungwararamunashe
This is a repeated warning message from ZISPA (who maintain the .co.zw domain name registry) about DNS errors with the above domain. For assistance the registrant is asked to DEAL DIRECTLY WITH THEIR REGISTRAR, AND NOT WITH ZISPA.
The registrar for this domain is webzim Their contact details are appended below.
ZISPA requires at least two nameservers for a domain with all nameservers responding authoritatively with valid SOA and NS records matching the registered nameservers. This requirement does not appear to have been satisfied for zarchy.co.zw. (An authoritative nameserver is a working nameserver that holds the actual DNS records for a particular domain and can therefore provide definitive answers to queries about the domain without having to look them up on another nameserver.)
If the domain is needed then the domain owner should contact the domain registrar (not ZISPA) if they need advice on how to fix the configuration of the domain’s nameservers. If they wish to use new nameservers then that must be arranged through the registrar, not ZISPA.
If the domain’s nameservers are not configured correctly and if we have not had any response from you, the domain will be deleted automatically on Sat 22 August.
See check on domain’s registered nameservers below:
Checking whether the above nameservers are authoritative for zarchy.co.zw:
ns1.infinityfree.com: Not authoritative. Status: REFUSED (Nameserver refused to respond)
ns2.infinityfree.com: Not authoritative. Status: REFUSED (Nameserver refused to respond)
ERROR: No authoritative nameservers found for zarchy.co.zw. ZISPA requires at least two.
Note that ZISPA’s Terms and Conditions require at least two nameservers for the domain to be operational at all times, including at the time of initial submission.
The domain will be tested automatically on a daily basis for up to ten days. You will be sent a notification once the nameservers are found to be correctly configured. Otherwise the domain will be deleted on the date indicated above.
Alternatively, if all else fails and you have not been able to get it resolved with your registrar, then contact us.
Looking at the message and your domain name, I don’t see any issues. Your domain name is correctly set up on our end, and has correct A records, SOA records and NS records. Your domain name is fully working, and so our our nameservers, so I’d say that your domain is compliant with that part of ZISPA’s terms.
So I don’t know why ZISPA is complaining about the nameservers.
If ZISPA really doesn’t like our nameservers for some reason, you could also switch to other nameservers, like those from Webzim (if they provide them) or a specialized provider like Cloudflare. You can then point the domain name to our website hosting from those external nameservers:
I will stress that it’s silly to have to jump through these hoops to work around what I can only describe as broken registry checks. But the option exists, if you need it.
