dns limitation workaround
Hi,
just joining InfinityFree…such a great service!
anyway, i see its very limited from dns management (because its not really meant to be)
eg: we cannot set txt, a record
another way, is it possible if i’m using external dns management and pointing (eg: www) into my free account?
kindly advice,
thanks,
If your are comfortable managing your own DNS records, you can use a third party DNS service without any problems.
To do so, you need to point your domain name to your account’s IP address. You can find out the right settings by following this guide: https://infinityfree.net/support/find-your-ip/
Note that your domain must be added to your account first before you can do this, and you must use our nameservers to add the domain to the account.
thanks for the reply,i’ll try it…
