Disk Quota Guard — Storage plan limit is not configured
https://euroexplorehub.com
Installation failed: Storage plan limit is not configured on this website.
Hello InfinityFree Support,
Website: euroexplorehub.com
Hosting account: if0_43270570
WordPress plugin installations fail with:
“Installation failed: Storage plan limit is not configured on this website.”
The host-installed Disk Quota Guard must-use plugin also displays:
“Storage enforcement unavailable.”
“Storage limit is not configured on this website.”
My hosting account has a 5 GB storage allocation.
Could you please check whether the website’s storage plan limit is correctly provisioned and whether Disk Quota Guard can retrieve it?
If this is a hosting-side configuration issue, please correct the configuration. I am not requesting an increase to the free hosting limits.
Thank you.
I couldn’t find anything on the forum or in the knowledge base about “Storage plan limit is not configured” or a Disk Quota Guard plugin, so I can’t tell you what causes it.
Did plugin installs ever work on this site, or have they failed since the account was created? And do you get the same message if you try the install from euroexplorehub.infinityfreeapp.com, the free subdomain on the same account? The answers would show whether this is about the account’s setup or only about the custom domain.
For what it’s worth, 5 GB is the storage limit we set on accounts, so the allocation you describe matches:
Your inquiry is filled with information that does not seem to match our hosting. We don’t install any must-use plugins to your website. I also cannot find any information online of what is the “Disk Quota Guard” plugin you are describing.
Yes, I’ve never heard of that plugin, we definitely didn’t install it to your site. Is this a new site you installed here or one you migrated from a different hosting provider that may have installed their own plugins?
In any case, you may want to uninstall that plugin, I see no reason to keep it.
Thank you for checking. Yes — this site was migrated to InfinityFree on 26 October 2026 from my previous host, using the Backup Migration plugin (a full restore). The Disk Quota Guard message appeared after that restore; I never installed such a plugin myself. Plugin installs have failed with ‘Storage plan limit is not configured on this website’ since the migration. I will remove the Disk Quota Guard must-use plugin after my account reactivation and test a plugin install, and I will also test on the free subdomain euroexplorehub.infinityfreeapp.com and report back. Could you confirm where a must-use plugin like this is normally located so I remove the right files?
Must-use plugins locate at <WordPress Directory>/wp-content/mu-plugins. That plugin must have been installed by your previous host which does not apply here.
Yes, that tells me that it’s very likely that this Disk Quota Guard plugin was something added by your previous hosting provider.
And that would perfectly explain the “Storage limit is not configured” type errors you got. The plugin communicated with your previous hosting provider’s server to check your hosting plan so it knows how much disk space is available to your account. Our servers don’t have that, so the plugin breaks.
So yes, this is 100% an issue introduced by the migration, and the fix is to remove the plugin.
