Delete unused domains
I already have 3 free domains, how do I delete unused domains to add another one?
First, note that a hosting account doesn’t equal only one free domain to use on every hosting account you create, as a hosting account can contain multiple domains, so you can host multiple websites on a hosting account as long as the limits of that hosting account will allow it. So you can still add on the hosting accounts you have more subdomains under the “Sub Domains” section of the Control Panel or the “Domains” section of the Client Area for your hosting account.
Haha, very cool, I didn’t know
What is the thing that governs every hosting account? Space for example?
Every hosting account has limits to respect, which are all documented on Fair Usage Limits, and also the same amount of space and bandwidth (though I think you won’t be able to reach the space limit normally because you’ll hit the INODE limit before you hit the space limit). Some of those are daily limits, so limits that are reset after a day and/or after you got the chance to reach that limit after a day, when you also have some chances to getting your hosting account to use less resources, while the only one that doesn’t let you do anything until you delete some files/folders after you reached it is the INODE limit, which gets updated after 8 hours.
Is the limit five GB per hosting account?
Yeah, the space limit is 5 GB per hosting account.
I don’t understand what you mean by daily limit. Please send me a guide explaining the matter in detail so I can be informed
There are multiple daily limits.
See the articles in the Fair Usage Limits for more information.
This was helpful thank you
