How can i delete SSL certificate from SSL Section?
Go to app.InfinityFree.net/ssls and select the SSL domain you wish to remove. Scroll to the bottom of the page and click “Revoke Certificate”. Then, navigate to the cPanel remove the certificate there as well. Make sure to remove all HTTPS-forcing code as well, otherwise your site will be inaccessible.
Note that Revoking a certificate doesn’t remove it. It only changes the status from Issues to Revoked. And note that GoGetSSL certificates don’t support revocation.
This was changed recently so you can only delete SSL certificates which are in status “Draft” now.
Why do you want to delete a certificate in the first place though?
Ok
