Database problems
I have a billing program and everything works perfectly but there are times when the connection with the database does not work and also the infinity free database is deleted, this only happens for short periods and returns to normal.
The database disappears from that section, it does not appear there for a few minutes when the error occurs.
Please go through the forum before you post, read this:
https://forum.infinityfree.com/t/mysql-databases-missing-sql-2002-connection-refused/56451/20
thanks
