Database Help
play.rag3d.rf.gd
ETIMEDOUT
It keeps giving me an error that says “Server ETIMEDOUT”
I don’t know how to fix this issue or even check the status of the database, can I get help with this?
const mysql = require('mysql');
const connection = mysql.createConnection({
  host:`sql<numbers>.epizy.com`,
  user:`epiz_<numbers>`,
  password: `<password>`,
  database: `epiz_<numbers>_Accounts`
connection.connect();
Is there an error with this code?
Yes, that looks like Node.JS code. We only support PHP. Try using that and see if it works.
But other than that i seen no error. Can you direct us to where the error is (if you’re still having it)?
let me try it real quick
