Database does not appear
[Website URL]
(https://ligafju.infinityfreeapp.com/)
Error establishing a connection to the database
Not only does the Dashboard say that there is no database in my account, but the original settings of the database created when installing Wordpress are different from the data displayed in the Dashboard and even if I change them the site still has the same problem.
If you installed your website with Softaculous and the website works, then you can assume that the configuration in your website is correct.
However, there used to be a bug that databases created through Softaculous were not visible in the control panel or client area.
Fortunately, this is easy to fix: just try to create the database with the same name from the control panel.
Don’t worry, this won’t delete your database or its contents, all it will do is fix the database permissions of the database so it’s accessible.
Thank you!
I created the Database as instructed and updated the Wordpress settings to the panel username and it worked.
