Database connection problem - please advise!
Hi, I’m trying to setup my forums for a project but whenever I enter the DB credentials into my config file this always comes up
Screenshot by Lightshot
I’ve deleted and created a new database like 4 times, only to get the same result. I even deleted the files from htdocs and re-uploaded them to see if that’d change anything, but no luck there either.
Please help!
Yes, I’m entering the correct connection information
EDIT: NEVERMIND I GOT IT TO WORK.
SECOND EDIT: NEVERMIND THIS IS HAPPENING AGAIN SAME MESSAGE AS THE SCREENSHOT ABOVE.
Please help!
Possible Reasons are maybe you entered localhost instead of provided mysql database hostname, maybe user permissions are not properly provided to database user for database on which you are installing forums.
By taking a look at the above screenshot it seems like permission to database user is not provided for database or you are using a wrong password. Double check the credentials.
Does your problem share similarity like this one?
Please help!
don’t think so lol.
actually managed to fix it again. I don’t know, seems like an on and off issue for the software I’m using.
