Danisouza.pt is already assigned and in use.2
danisouza.rf.gd
(domain) is already assigned and in use.2
I’ve seen the other topics about this same error but the domain was registered couple days ago and the first thing I did with it was try to add it as addon domain here.
I have just one account here.
Thank you
It looks like someone else owned the domain shortly before you registered it, and they also hosted the domain with us. It’s still assigned to an account created by (presumably) the previous owner.
Seeing how the domain registration is definitely newer than the account the domain is assigned to, I believe you that the domain is yours. I’ve removed the domain from the other account, so you can now assign it to your account.
This solved the problem! Thank you very much!
