I am getting fed up with coding issues nothing as it was and much has been lost even the w3 schools stuff does not work on your sight idk why
for example http://www.deniserose.epizy.com/fetch_sql2.php
echo '<td id="igap2"><div id="outer_img3"><img id="artwork" width="35" height="35" class="artwork" alt="album" src="data:image/gif;base64,' . $base64artwork . '" </img></div>';
echo '<div id="overlay"><img src="images/SpectrumAnalyser.gif" width="30" height="15"></img></div></td>';
and http://www.deniserose.epizy.com/music_playing.php
<div id='outer_img' class='outer_img'><img src='images/nowplaying_artwork_2.png?t=<?php echo time();?>;' id='np_track_artwork' alt='Playing track artwork' ></div>
<div id='overlay'><img src="images/SpectrumAnalyser.gif" width="30" height="15"></img></div></td>
As the first does not work? Now neither does even more the audio controls don’t seem to register either
Is nothing stable on your site it doesn’t seem to work with anything for 1.5 hours then changes
I think this is why fetch I failing yet I am closing $con=null how can it be using more than one or two connection at most ?
try {
$conn = new PDO("mysql:host=$servername;dbname=$dbname", $username, $password);
$q = $conn->query($sql);
$i_count = $q->rowCount();
} catch (PDOException $pe) {
die("Error occurred:" . $pe->getMessage());
$conn = null;
1. Request URL:
2. Request Method:
GET
3. Status Code:
500 Failed to write /read from SQL.SQLSTATE[HY000] [1203] User epiz_33087480 already has more than 'max_user_connections' active connections
4. Remote Address:
185.27.134.150:80
5. Referrer Policy:
strict-origin-when-cross-origin
1. Response HeadersView source
1. Connection:
keep-alive
2. Content-Type:
text/html; charset=UTF-8
3. Date:
Thu, 22 Dec 2022 09:11:46 GMT
4. Server:
nginx
5. Transfer-Encoding:
chunked
2. Request HeadersView source
1. Accept:
text/javascript, text/html, application/xml, text/xml, */*
2. Accept-Encoding:
gzip, deflate
3. Accept-Language:
en-GB,en-US;q=0.9,en;q=0.8
4. Cache-Control:
no-cache
5. Connection:
keep-alive
6. Cookie:
_test=6e115e5362df5ab59656bdef8a3d164d; _ga=GA1.2.1049512228.1670761460; __gads=ID=4dbac2a3c84af722-22ca1f35d7d700cf:T=1670761461:RT=1670761461:S=ALNI_MYh1TR0fvCHN_hPVm_IuC9SgQWEhQ; __test=1fdfb273aa678c70e40cf7277f6b164e; _gid=GA1.2.1335419779.1671447514; __gpi=UID=00000ba838b2857f:T=1670761461:RT=1671690892:S=ALNI_MbXZ6MFlIIWT5zMopKFjoTCf8jX-w
7. Host:
8. Pragma:
no-cache
9. Referer:
10. User-Agent:
Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36
11. X-Prototype-Version:
1.7.3
12. X-Requested-With:
XMLHttpRequest
