How could i change the language in my cpanel.
“epiz_23937743” my cpanel is in chinese and i would like it to change back into english.
cant see a language option
You need to edit your profile to make your Control Panel be available in English again. To do that, go to your Client Area, then click on “Profile”, then on “Edit Profile”, then on the dropdown of “Preferred Language” change the language to whatever it will be to English, then click on “Save Language”, and clear your cache and go to your Control Panel again.
@Ergastolator1 i cannot find the profile. where are they stored?
haha I know Chinese XD
Click on 登出 (logout at top right corner)
Select your language (If in Chinese: 語言)
Choose English
The Profile button can be found in the menu on the left side of the page in the client area on https://app.infinityfree.net
thank you @Admin the problem is solved!
