Cpanel err_connection_timed_out
Good afternoon!
I haven’t been able to access my cpanel for the last 30 or so minutes. I keep getting an “err_connection_timed_out” error. Anyone else have this problem?
Edit: apparently so. :slight_smile:
/jenny (epiz_28595258)
Hello, it seams this is the new internal issue, hopefully it has a quick fix.
Ah, I see. It’s actually working for me again now, albeit with a “NET::ERR_CERT_AUTHORITY_INVALID” warning in my browser. Hopefully they’ll get it sorted soon, as you say. :slight_smile:
Yes, I believe that the SSL certificate for the panel has expired. Should be an easy fix!
Real certificates have “disappeared” (currently unavailable) due to some works in infrastructure , so you can see some old initial ones that expired in 2020.
The same is true for all other versions of the control panel
Those pesky little SSL certificates. Coincidentally, I am currently working on getting my own website up and running via https/SSL. When cPanel suddenly became unavailable, my first thought was that I had somehow messed up the certificate installation and broken my entire account, lol. Guess not. :slight_smile: :crazy_face:
@JennyR hahaha
btw. mixed content
because somewhere else on the website you have a URL that is HTTP instead of the HTTPS protocol
otherwise the certificate is ok
@Oxy Thanks for the feedback! :slight_smile: I installed a search and replace plugin (as suggested by yourself in another thread) and used it to update all (hopefully) urls in the database. Are you still getting the mixed content warning?
it’s okay now :+1:
AND HOSTING CONTROL PANEL ALSO !!!
cert is back :slightly_smiling_face:
Thanks for your help. :slight_smile:
