Could not connect to FTP
Hi,
I can not connect to ftp.
My ftp host is ftpupload.net
Username is epiz_22341323
And password is ********
Filezilla is showing error:
Estado: A resolver o endereo de ftpupload.net
Estado: Conectando 185.27.134.11:21…
Erro: Conexo expirou aps 20 segundos de inatividade
Erro: No foi possvel conectar ao servidor
Estado: Aguardando para tentar novamente…
How can I solve this?
@guimota said:
Hi,
Have you tried reading this?
https://forum.infinityfree.com/discussion/4314/could-not-connect-to-ftp#latest
yes> @UnknownLolz said:
@guimota said:
Hi,
yes
I used FileZila to try to connect.
Are you sure your using the correct password or username and the host name?
Yes, every hour of error.
port = 21
The error makes it look like you are unable to connect to the FTP server. Do you see a password prompt when you open ftp://ftpupload.net in your web browser, or does the page keep loading indefinitely?
If that page doesn’t load either, it’s possible your internet provider or network administrator is blocking access to the free hosting IP addresses. If so, you may want to contact your ISP/administrator about this to ask if they block this IP.
Also, please don’t create two topics about the exact same issue from the exact same place.
Hi,
Username is epiz_22346842
And password is **************
Screenshot by Lightshot
