Cookies not enabled error
seahorsearts.co.uk
Re: if0_40379568
Cookies are not enabled.
It appears your browser is not accepting cookies, please enable cookies to continue to this page, or disable ‘private’ web browsing mode.
Instructions to enable cookies for all browsers can be found HERE
Still getting this cookies message, been over a week now, or sometimes it’s an htaccess error
I indeed get the same error when I visit your site. However, visiting my own site hosted on InfinityFree has no issues, so it might not be an issue with the platform. Can you please show your .htaccess file?
Have you tried accessing your website via ftp and then deleting the lines containing define(‘COOKIE_DOMAIN’ and define(‘COOKIE_SECURE’) in wp-config.php ?
Perhaps other things but the problem often originates from the config.php file (in Wordpress). Check too define( ‘DB_HOST’ and db config is similar to your MySQL database name..
No, this screen comes from iFastNet’s security system and has nothing to do with WordPress.
wordpress config and .htaccess problem :slight_smile: https://seahorsearts.co.uk/wp-login.php?i=3
It’s very clear that the OP is having issues with the .htaccess file being wrongly configured. The website just happened to have a WordPress installation but that doesn’t say anthing because this error message does not come from WordPress at all. The security system is saying that Cookie is not enabled and the security cookies are not managed by WordPress.
Ok :slight_smile: first the htacess must be fix.
Please try disabling Cloudflare’s Rocket Loader feature. I think it interferes with our security check.
Rocket Loader can be useful if it works, but it has the tendency to break website code.
