Control Panel not available
I’m getting the message below when I click on the green control panel button. Any ideas? thanks
cpanel.infinityfree.com sent an invalid response.
  • [Try running Windows Network Diagnostics](javascript:diagnoseErrors()).
ERR_SSL_PROTOCOL_ERROR
Please try https://cpanel.byethost.com
thanks, but that is just generating the same message
just tried a different browser and got the same message
Secure Connection Failed
An error occurred during a connection to cpanel.infinityfree.com. Peer reports it experienced an internal error.
Error code: SSL_ERROR_INTERNAL_ERROR_ALERT
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
Please contact the web site owners to inform them of this problem.
iFastNet migrated again, but they didn’t migrate the SSL certificates,
Choose one below:
(Insecure)
http://cpanel.infinityfree.com
(a bit more secure)
https://panel.myownfreehost.net:2083
as i can’t access the control panel, even if i wanted to deactivate my account, looks like my domain name will be locked to infinity for quite a while?!?!?
thanks for those links. The username and password i used to set up my infinity account don’t work on either of those!
Those links to the control panel worked for me but when i set up the CNAME records there and try to verify my domain, it says " Unable to login to your hosting account. Please verify you can login to the control panel from the client area, and reset your account password if this doesn’t work."
That’s also the result of the control panel being unreachable.
But let’s continue in this other topic and avoid fragmenting the information about the issue in multiple topics.
