phpMyAdmin database Connection error :
#This page isn’t working
185.27.134.10 redirected you too many times.
ERR_TOO_MANY_REDIRECTS
http://185.27.134.10/db_structure.php?db=
At the same time, my website also has the following error:
I fixed the panel password once to fix the problem and entered a new password inside the site config but the problem was not resolved
Admin
October 22, 2019, 7:23pm
2
I’ve reset your database permissions. Can you please try again now?
Thank you database connection problem in phpMyAdmin solved, but when installing the cms given the correct database username and password , communicating can’t be established with sql100.epizy.com
Admin
October 23, 2019, 11:26am
4
After changing your hosting account password, did you also update the configuration file or your software to use the new password?
If you did, can you please share the full error message you see as well as the URL you see it on (if possible)?
thank you for supporting, I changed the password again in the edit account panel and the problem was resolved
system
Closed
November 23, 2019, 10:22pm
6
