Connection Problem
Bonjour, je n’arrive pas à accéder à mon site (https://kor-shop.infy.uk) depuis mon IP “176.150.166.108”. Est-elle bloquée ?
Please note that this is an english-only forum!
translated version:
Usually the problem is your ISP, ad blocker or your browser. Try using a VPN if possible, turning your ad blocker off (if you have one), and if that doesn’t seem to help, try visiting infy.uk itself.
If you can’t access infy.uk itself it’s most likely your ISP blocking it. Perhaps you can try using a different free subdomain?
Your site is working fine for me. Can you elaborate on what you mean by “I can’t access my website”? What happens instead? What do you see?
The problem is that I can’t access it with my local Wi-Fi, even though it worked when I first started developing the site. Also you are right because all my friends and I on my 5G network can access the site. So the problem is that I can’t access my site admin page even though all the files are on my personal PC without a wifi card.
sounds like either your ISP or firewall are blocking the domain
