Connection problem with MYSQL
Good morning.
All of a sudden I can no longer connect to the DB.
The connection parameters are correct.
$servername = "fdb31.freehostingeu.com";
$username = "3967282_users";
$password = "XXXXXXXXXX";
$dbname ="3967282_users";
$conn = new mysqli($servername, $username, $password, $dbname);
### Website URL
La pagina non funziona
myawesomeworks.free.nf al momento non è in grado di gestire la richiesta.
HTTP ERROR 500
Davide.
Looking at your code, your credentials do not look like InfinityFree credentials. Please go to the Client Area and copy the credentials from there.
Sorry, you’re right, I copied and pasted wrong.
The Parameters are:
$servername = “sql310.infinityfree.com”;
$username = “if0_35438125”;
$password = “xxxxxxxxxxxxxx”;
$dbname=“if0_35438125_mydb”;
But it doesn’t connect.
Read on
many thanks KangJL.
Having a stack trace it was easy to find the solution.
Davide.
