Connection failed:php_network_getaddresses: getaddrinfo failed: No address associated with hostname
<?php
$servername  = "sql306.epizy.com ";
$username = "epiz_33516752";
$password = "*********";
$db = "epiz_33516752_db ";
$conn = mysqli_connect($servername, $username, $password, $db);
if(!$conn){
    die("Connection failed:" . mysqli_connect_error());
There is password
The extra spaces may be causing it. Remove all extra spaces and chars from your code.
Thank you!
No problem glad I could help
