Concrete 5 Installation Error
Hello there.
When trying to install Concrete 5 via Softaculous I’m encountering this error:
The following errors were found :
Could not make the query numbered : 132
MySQL Error No : 1071
MySQL Error : Specified key was too long; max key length is 1000 bytes
Is there any other way to install concrete 5 without exceeding the Database Key Length?
Best Regards,
kartoffelx86 :slight_smile:
As far as I know, no, there is no way.
You may wish to check the other related topic as well: https://forum.infinityfree.com/topic/547/mysql-installation-of-a-clean-concrete5-failed
