Comodo SSL certificate installation
Hi,
I got two files from comodo for the SSL installation. I uploaded the content of the .crt file but I can’t find where to install the CA-bundle file.
Can you help me with the install please?
Thanks.
You can’t upload the CA bundle on free hosting. However, most browsers will accept the certificate without the CA bundle anyways.
Yes, all the popular browsers will accept the cert without the CA bundle. The only disadvantage I’ve found is that using Firefox on a public (specifically a library) computer, it will think the actual cert is the CA root for some reason.
Thanks guys.
