hello against
there’s something i’ve got against with php.
<!-- INCLUDE overall_header.html -->
<div align="center">
<h2>My Den</h2>
<br>
<br>
<div class="panel">
<!-- PHP -->
include("config.php");
// Create connection
$conn = mysqli_connect($dbhost, $dbuser, $dbpasswd, $dbname);
// Check connection
if (!$conn) {
die("Connection failed: " . mysqli_connect_error());
$sql = "SELECT crany_name, crany_breed, crany_gender, crany_level FROM phpbb_crany ORDER BY crany_id";
$result = mysqli_query($conn, $sql);
if (mysqli_num_rows($result) > 0) {
// output data of each row
while($row = mysqli_fetch_assoc($result)) {
echo "name: " . $row["crany_name"]. "<br> ";
echo "<img src="/img/image.php?crany_id=" . $row["crany_breed"]. "" alt="crany">"
} else {
echo "No Cranies in your den";
mysqli_close($conn);
<!-- ENDPHP -->
</div>
</div>
<!-- INCLUDE jumpbox.html -->
<!-- INCLUDE overall_footer.html -->
when i run the code gave me:
Parse error: syntax error, unexpected '=' in /home/vol6_8/epizy.com/epiz_23744660/htdocs/main/styles/template/den.php on line 26
how do i fix it . i don’t know how do i put <img>
tag into the echo()
thank you
The contents of the src attribute should have apexes instead of quotation marks, and goes the same on the contents of the alt attribute on the img tag; if you don’t correct it, it gives the unexpected = on line 26.
Maybe I’m just missing something but I don’t see your opening or closing tags for the PHP script ‘<?php' and '?>’
@thenicopanda , the PHP opening and closing tags are where the comments <!-- PHP –> and <!-- ENDPHP –> are.
My bad
maybe switch this…
echo “<img src=”/img/image.php?crany_id=" . $row[“crany_breed”]. “” alt=“crany”>"
to this
echo “<img src=‘/img/image.php?crany_id=’ . $row[“crany_breed”]. " " alt=‘crany’>”
I think the Quotation marks inside of your echo might be what is messign you up
Your quotation marks and apexes are not in correct disposition and correct form. This should make more errors in the code. Let me fix this for you and @anon19508339 :
echo "<img src='/img/image.php?crany_id=".$row["crany_breed"]."' alt='crany'>";
now i’ve bug at this line:
$sql = "SELECT crany_name, crany_breed, crany_gender, crany_level FROM phpbb_crany ORDER BY crany_id WHERE crany_user='.$_REQUEST['user'].';";
tells me:
syntax error, unexpected ''
Here’s the correct line:
$sql = "SELECT crany_name, crany_breed, crany_gender, crany_level FROM phpbb_crany ORDER BY crany_id WHERE crany_user=".$_REQUEST["user"].";";
system
Closed
July 28, 2019, 11:19am
10
