CNAME Records for Subdomains
Hello,
is it possible to add CNAME records for subdomains? I want to install a SSL certificate for one of my subdomains, but I am not able to verify it.
(I’m using the SSL CertificateTab from Infinityfree‘s Client Area)
Thanks!
SSL for subdomains is not supported at this time. Not only is there no way to add CNAME records for subdomains, the SSL/TLS menu won’t even let you add SSL certificates to subdomains if you have one.
Just from self experience: If you have SSL certificate installed on your main domain, you will have it for all subdomains.
